ISO removal
Slugger25
so the poly ones are thicker or harder to allow less drop, correct? is it the same for the front? If so I could add poly to the front to raise a little. I am looking for the more level look see below.
white95
Apex Junky
Admin
Prairieville, LA
Here's an idea, consider buying some ride-height-adjustable [weight jacker] lower control arms from M/M or another vendor. When I swapped the stockers out for my non-adj. tubulars, it picked the rear up at least .5" giving it that 'raked look' that I don't like, makes the handling sort of dicey sometimes.
Win
Kennesaw, Ga
I heard the Rear upper's that are adjustable will sometimes bind?? Have you guys had any issues with that??
Carolinastang78
