mark8 VIII, Cobra, lincoln 4v 03/04 cams specs
96blak54
Lawrenceburg Kentucky
Ill be issuing cam specs of Mark VIII, 03/04 cobra and Lincoln 4v cams specs....so stay tuned! I want to map out a set of 96-98 cobra cams, but don't have any on hand. Anyone willing to ship the cams to me for mapping, im all game! Give me a few days to repost......stay tuned!!
96blak54
96blak54
03 / 04 cobra cams!
NR-4903-543
NR-4947-547
Intake / Exhaust
.006
232° / 236°
.050
184° / 190°
.395" max lift
96blak54
96blak54
Continental 4v
Roughly early 90's
F2LE-6A270-AE
Measured on largest intake lobe.
Intake / Exhaust
.006
246° / 246°
.050
198° / 192°
.395" max lift
96blak54
96blak54
Ive nabbed a set of ....well....what ive been told is a set of 03/04 cobra cams. Ill be measuring them out soon along with cam part #'s and ill issue my findings!
Sent from my SM-G900P using Tapatalk
BigBore96
Mark 8, termi, marauder, and the mach you should find all the same.
All ex stock 4v exhaust cams should come out the same
99 has more duration on the intake than the above.
96 through 98 has a tad more than 99 and are the most desirable.
96blak54
96blak54
"The same" were the exact words we initially were told about non-pi & pi cams. Both groups were different, but no differences in the group. That turned out to be false. Although,....i do agree there most likely wont be enough differences with the 4v cams.
evilcw311
Most Evil Member!
Louisville, KY
I think y’all need more cams. Obviously 2 and 4 cams just doesn’t keep y’all busy enough.
And here I thought my life was complete only having to worry how one bump stick affects my life!!!! Lol
96blak54
96blak54
The beauty of 2 cams per head is lobe seperation angle change. Ill figure it all out here soon
SnakeBit!
Florida
they should be the same as your 01/20/17 post. be interesting to see....
BigBore96
The specs out for the 4v cams are based on actual measurements, not what ford claims. Many well respected people have come back and reported the same info.
bikeboy636
NORTH GA MTN
SO WHAT CAMS WOULD BE BEST FOR MY 4.6 TO 5.0 STROKER BUILD WHEN I PLAN ON RUNNING TWIN TURBO LATER THIS YEAR. SHORT BLOCK IS TEKSID BLOCK, MANLEY FORGED RODS AND CP RACING "TURBO PISTONS" 9:1 COMP. I HAVE A SET OF 2001 CAMS IN THE CAR NOW, I HAVE A SET OF LINCOLN MARK 8 CAMS AND I ALSO HAVE 03-04 CORBA CAMS? THANKS IN ADVANCE FOLKS!!!
96blak54
96blak54
Spent some time mapping cams again. I must admit a great level of tranquility when doing this. Its so peaceful!
Ive had the idea of swapping to 4v heads ever since the headgasket on my 5.4l 2v blew. I wanted to get actual 4valve open/close points on paper so that i could get the mathmatics figured out for a performance scenario. Lobe seperation and such....hold up. Let me explain.
The 4valve heads have 2 camshafts that operate the intake and exhaust seperatly. One cam for intake valves, one cam for exhaust valves. The biggest gain here is being able to alter lobe seperation angle. This angle is referenced from an imaginary center line from the exhaust open/close points and intake open/close points and the distance between these lines.
Its known that not much performance can be had by altering the intake valves operating points, but the exhaust is a different story.
Yes, more intake duration has performance benefits IF....you want to purchase new cams....but in this scenario we are utilizing what we have available on the cheap cheap! Ford factory parts!
Next post will be a big surprise! ...to the 4v community.
01yellercobra
I have a set of Ford GT cams on the shelf I really should install.
RevJon
