Mm caster Camber plate spacers
gumby5.0
Just curious to see what orientation you all have your spacers in. Im running c-springs with a 1/4 coil cut without isos, the drop is similar to super sports. I have 1big and 1 small up top and 1 big and 1 small on the bottom. Sound right?
Sent from my PC36100 using Tapatalk
JoshHooten
Hiram, GA
I have c springs with 3/4 coil cut with isos so I guess that would be about the same ,with the struts I have idk what kind they are.
I am running I think the 2 small ones on the bottom and the 2 large ones on top but the nut wouldent tighten down all the way so I put 2-19mm? washers I think on both sides and it worked perfect for my setup
G
gumby5.0
I think I may move a small washer down aswell as bring a big one up. I hope I'm not hurting my struts
peasant99
