My stance problem.
Untame-d
This is my stance.... It disgusts me. :angry7: I doubt the isos are in there.. would it make a good enough difference if I put them in or should I shop around for rear springs?
I have 1.25 wheel spacers since this pic. I'm sure the wheel wells with peel my tires off if I don't fix it.
hottwheels04
Mycar has a similar stance not as bad no offense as yours, but I found out why on my, I have lakewood lower control arms and eibach pro springs, and koni shocks and maxium motor upper control arms, I found out my lakewood lowers wrap around the axles there " race " setup so if I was to swap slicks in the back the cars stance would be higher in the back, If thats ur case youll kno if u were to put taller tires in back / race slicks etc.
cntchds
Iso's will not make that much difference. If you wouldn't mind measuring I know from the ground to the top of the rear wheel arches on mine are between 27 and 28 inches. I am using Mach 1 springs.
Pennywise2
I would definitely use all the spring insulators on your mustang.
What springs do you currently have?
The rear looks like it is sagging though.I would start shopping for new springs
like the Eibach Pro Kit springs.
Suprasuavy
