right I mean its just that easy Plug it in, download the tune and your good go to the strip and start running 10s. No need to worry about learning new software or the subtle nuances of tuning. We all wince at the idea of bama tunes which is supposed to know what they are doing so why would it take more then 5-10 mins on a youtube vid to be better then them, another email tune or a local tuner? maybe a wikipedia article or two? I mean you can see all the data live like you say? Sorry but I fell into this hole a while back and now after a LOT of learning I am still not sure I made the right decision. Someone told me the same thing "comes with a tune/self tuning/nearly plug and play and your off" and I have seen it thrown around since to ANYONE with out finding out if they are even remotely ready for it. Daryl and I have spoke on pm and on a couple of his posts and I like him and I with all due respect to him your suggesting to go to a standalone tuner to someone that currently has posts up about how to replace his IAC and remove his oil pressure sender. No offense daryl your not ready to go to a standalone and I know because I wasn't either.....
Projecting much?
I never said he needed to go stand alone. There is software that allows you to tweak on the stock ECU. Yes, there is learning involved. But most can pick up tweaking a stock ECU.
I guess you missed the last where I said I learned too.
But apparently I think too much of others. Good luck Daryl.
Projecting much?
If you are looking for another recommendation try Wild Pony Motorsports in Santa Clarita. He might have another recommendation based on your needs. I have asked around locally and he comes up quite often as a solid shop. He called me back on questions I had asked earlier and was super nice guy and just wanted to help.
Jake
I would absolutely stay away from Wild Pony. I've known Darren for years, we used to attend same track days, etc, and he's worked on my car plenty of times with ok quality of work, but he fucked up royally when he built my current engine. And why I say built, I mean he let his shop apprentice build it (with very little experience). The motor came back from him leaking from every end, blew a header gasket, snapped a rocker arm, wasn't tuned properly. Every time Darren would break something while building it, I would get the bill. I kept coming back to have him fix it, and would come back with more issues. Eventually I realized that in order to me to have any actual success with my engine, I have to take it somewhere else, because doing same thing over and over and expecting different results is a sign of insanity. When a different shop went through the motor, they found that torque specs were all over the place, there wasn't any locktite on the cam retainer plate, so cam pretty much ate itself while sending metal through the motor, basically I got really lucky that I took the motor to the other shop when I did, because if I wouldn't, it would have failed catastrophically.
Darren may hold his head up high, and think he's great, but it's far from the actual truth. I guess I should have picked up the clues about his quality of tuning when he can't even figure out how to make his own race car idle, or the fact that he gets really low numbers on dyno consistently. Just to give you an idea, Darren made 308 rwhp on DynoJet, while Ray from FTK made 358 rwhp on Mustang Dyno (which reads low by comparison to jet, that's about 400 rwhp converted to DynoJet numbres). FTK tune drives perfect makes nearly 100 rwhp more, while Darren's tune was complete garbage, would stall pretty much every time I'd let it get near idle while rolling, wasn't able to make a full wide open pass without stumbling. I cannot go out of my way enough to dissuade people from ever entering Wild Pony.
Fantastic, ReplicaR! Just what I’m looking for... and close! 15-20 minutes max. I will definitely touch base with them. My supercharger is on its way back from Jon Bond Performance as of today. Soon as it arrives, I’ll piece it back together and get ahold of FTK and have them do for mine exactly what they did for yours: full range drive ability.If you're near Ventura, there is no one better than Ray at Full Throttle Kustomz in Fillmore. He's using a Mustang A248 dyno, which is a loading roller, so it allows him to tune various loads, all kinds of different situations, etc. They really pride themselves on tuning the cars for great driveability and safe reliable power, and so far I can vouch for that. Before I went to FTK, my mustang had pretty iffy street manners, it would frequently stall, was difficult to drive at the lower rpm range. All of that is gone. While on the dyno we also found out that one of the cylinder banks is running leaner than the one one, and that my fuel pump is running out of fuel near the top, something that none of the previous tuners have ever mentioned.
https://fullthrottlekustomz.com/
Well that is an experience far beyond what I had. Mine have only been phone conversations. I will take everything you laid out into consideration and stay away. Luckily around here we have a lot of choices so I have never had a need to go out to Santa Clarita. Thanks for letting me know.
Jake
if you want it done right the first time do it yourselfI would absolutely stay away from Wild Pony. I've known Darren for years, we used to attend same track days, etc, and he's worked on my car plenty of times with ok quality of work, but he fucked up royally when he built my current engine. And why I say built, I mean he let his shop apprentice build it (with very little experience). The motor came back from him leaking from every end, blew a header gasket, snapped a rocker arm, wasn't tuned properly. Every time Darren would break something while building it, I would get the bill. I kept coming back to have him fix it, and would come back with more issues. Eventually I realized that in order to me to have any actual success with my engine, I have to take it somewhere else, because doing same thing over and over and expecting different results is a sign of insanity. When a different shop went through the motor, they found that torque specs were all over the place, there wasn't any locktite on the cam retainer plate, so cam pretty much ate itself while sending metal through the motor, basically I got really lucky that I took the motor to the other shop when I did, because if I wouldn't, it would have failed catastrophically.
