One Wheel sticks out more then the other? HELP!!!
GMSMOKR
Usa
Ok the car is put up for the year and two weeks ago I took off the After Markets and put the Factorys back on...and just today I just noticed that one wheel sticks out more then the other...GRRR Now what? Its about and 1/2 in off
HEEELLLLPPPPPP!!!
RichV
CO
Either rear bushings are sloppy or you have a bent control arm, or both.
The other would be if the tub is tweaked from an accident.
My 86 Saleen had that issue. It was just the control arms weren't centering the rear end correctly. Get some new upper and lower CAs.
GMSMOKR
GMSMOKR
Usa
Thx again Rich...I bought her brand new in 3/97 ..Never an accident...But I was just shocked to see that..I will Order and install the New CA's in the next couple of weeks.
RichV
CO
Check out MM or J&M, and keep the upper CAs stock replacements. That shouls do it!
GMSMOKR
GMSMOKR
Usa
Thx Rich...Lmao..I was looking for a pair now @ work...more so BBK's but if you think J&M and MM is better then I will check them out.
Tony
ohio
i had a bent axle shaft when i first bought this car. wasnt bad enough to make the car shake but made my drivers side rear look to be out a tad when i would be parked a certain way. def noticeable. if you have it parked and it is sitting like this: \--------- it will stick out at the top. this was just my issue, not saying its yours. to see just simply jack your rear up and spin your back tire.
BigBore96
Invest in a quality LCA like the MM like Rich suggested. You won't regret it.
GMSMOKR
GMSMOKR
Usa
Thx Tone...I will do that as soon as I get home ...just to double check.
GMSMOKR
GMSMOKR
Usa
Mannn..Bigbore..Those MM...Maximum Motorsport LCA's cost more then more the J&M and BBK's wow...I do like the Adjustable kind :).
Carolinastang78
