Pats key reprogramming
J_lope82
South Texas
96 mustang gt
I borrowed a scan tool to reprogram a new key since I bought the car with only one. The only option this scan tool gave was to erase key codes. So I erased key codes and then the car would die after start up. I erased the codes again and cycled both keys right after and now they both work. I am wondering if that’s the correct way to reprogram keys or did I just erased all key codes and now no keys are program and any key would work.
joemomma
Not sure, I suppose you could test with another key that you haven't programmed? Maybe buy one at Autozone (do they even sell them?) and then return it?
I thought that you were only able to store 3-4 codes before it was full and then needed to have the memory deleted and then you could store more but I only had to mess with it once years ago now.
OpalFrostGT
Whitney,TX
My apologirs to you joemomma, I did not see your post. We were probably writing at almost the same time and your post popped up before mine.
J_lope82
J_lope82
South Texas
Well the new key works now when before it didnt and now the anti-theft light does not come on. I’m wondering if the anti-theft system is fully disabled. Is there even such thing?
when you said you cycled the keys I was assuming you meant you programmed them? What does cycling mean to you?
J_lope82
J_lope82
South Texas
I moved the keys inside the ignition cylinder from off to on back to off.
J_lope82
J_lope82
South Texas
I’m not sure if by doing that they got programmed or they just work because I inadvertently disabled the anti-theft system if that is even possible.
if the car is starting then they are programmed. I Thought you had to leave the key in the ignition for 5-10 mins for it to program
1998MustangVert
Buffalo, NY
Sorry to push into this forum, but I just ordered a few new keys to replace mine. After 23 years they are pretty beat up, one is cracked at the loop it can’t be used on a key ring anymore. I don’t know if any previous owners had keys programmed that were lost or never distributed from one owner to another… I Have seen that the max number of program keys is eight, but I’m not sure what happens if I hit that max number. Does it just stop excepting new keys, or will it override the oldest programmed keys? I can’t seem to find any information on this online. Thanks!
J_lope82
J_lope82
South Texas
You can erase the old ones and just program the ones you bought.
1998MustangVert
Buffalo, NY
I assume using forscan? I really don’t want to remove any keys because if they work they’ll be good to have as a spare if something happens. I also don’t want to get into using the computer because I don’t want to mess anything up.
J_lope82
J_lope82
South Texas
Forscan has the capability to program new keys including the ones you already had.
1998MustangVert
Buffalo, NY
I was able to use FORscan and that cable to erase and reprogram the PATS keys. My hunch was right, there was an additional key somewhere that was programmed to my car, but no more! Thanks so much for the advice!!
Ludillla
