Pedals for heel-toe?
amf201091
Omaha, Nebraska
My gas pedal was sloppy and had a bunch of slack so I added 2 zip ties to it. The problem now is I can't heel-toe because when I fully press the brake, it sits much lower than the gas pedal. Does anyone know how to solve this issue? I could remove the zip ties but then I wouldn't be able to reach WOT.
Burninrock24
Minneapolis, MN
Not trying to ask a dumb question but are your brakes nice and firm or are you putting the pedal to the floor to stop? You should be able to heel toe if you are actually using your heel. I agree its awkward to try to use the ball of your foot if you're really plunging the brakes.
Makoto
Houston
i spaced the gas pedal like half an inch from the firewall and pushed the clutch back about the same amount by modifying the swing arm. its pretty close now.pedals.jpg
