popping lowering springs?
94mustanggtfast
iv had a popping noise coming from my driver side front. i thought it was a ball joint but it isnt. would an aftermarket lowering spring pop? not all the time but when i put it in reverse or drive it pops
could be:
control arm bushing has rotted out allowing movement.
spring could be cracked.
ball joint could be failing.
steering shaft rag-joint could be rotted.
steering rack bushings could be rotted.
brake caliper could be loose.
white95
Apex Junky
Admin
Prairieville, LA
Do you have the rubber isolators on the springs? Could also be worn control arm bushings.
spring may not have been placed in the a-arm's cup properly during install as well. perhaps the coil is piviting and bonking the a-arm when in motion.
94mustanggtfast
yes the rubber isolator is on the spring and it is installed correctly. how could i figure out if something suspension wise is bad? how do check?
jack up the car and try and jack the tire up and down....
get under there and inspect the rubber
Mystic SVT
Replace your rack & pinion bushings with new ones. I went ahead and installed MM solid mount bushings. Also did new sway bar endlinks (1.5" shorter than stock) and my popping noise I had went away. Don't know which one of the two fixed the problem but I can tell you that the rack and pinion bushings were shot.
Suprasuavy
