Replacing tie rod ends
GT Rob
Houston Texass
Go to change out my tie rods tommrow. What's the best way to take them out and the replacing with the good ones any input would be helpfull
1997gtRioRed
jack up car
take off wheels
remove nut that connects tie rod to knuckle
remove outer tie rod
reverse for install
it is easier than changing your oil. well, without an impact gun it might be a PITA
then get an alignment, also ask if there is any discount for just a toe and go, some places do. i can have then out the door in roughly~10 minutes start to finish if its just a toe adjustment
if its just outter be sure to mark where the nut is on the rod before losening it.
then you can place it back in it's original location.
GT Rob
GT Rob
Houston Texass
Bumpsteer kit. I've heard of it but never thought anything about it what's it do
97FloridaGT
A BFH is your friend. For a redneck toe n go, grab another person and a tape measure and measure center to center on the front and rear of the tires halfway up.
GT,
bumpsteer kits can get somewhat complex.
take a look at Maximum Motorsports' website - its got some solid tech info on it for bump steer kits and proper installation.
Here is the kit i use:
http://www.maximummotorsports.com/store/index.php?main_page=product_info&products_id=450
it requires having the spindle drilled.
If you dont want to drill the splindle, here's their tapered kit:
http://www.maximummotorsports.com/store/index.php?main_page=product_info&products_id=451
basically, (and im NOT a suspension expert), these give an added range of adjustment for proper suspension travel in a hard turn or going over a bump.
joekd
Ct
When I did outers on my 00 the night before I hit them with a good shot of spray paint right at the threads, this way when I put in the new ones I had a good idea where to line them up so the alignment wouldn't be too bad until I could get to the shop
GT Rob
GT Rob
Houston Texass
Just finished up with the tie rod ends whent smooth and even put my front lowering springs in the springs that where in there where cut so hopefully it rides better with the lowering springs in. Thanks again for all the input guys
peasant99
