SN95 4.6 4V boosted dyno #s
This sticky is for all 4.6 4V boosted setups.
List your year, engine mods, and any pertinent changes from stock on how you made the #s. Also list the trans you have.
MustangChris
Aurora, CO
2004 mustang cobra (swap)
1996 mustang gt T-45 (OEM)
"power" mods (things that could effect dyno results):
JLT intake + filter
acuufab throttle body + plenum
Drewzilla ported eaton M112 (Heads by Drew - Aurora, CO)
Billetflow 3.400 upper pulley
Metco 6# lower pulley
kooks long tube headers (3" collectors)
custom built catted x-pipe (3" all through)
Jone's Exhaust chambered mufflers, dumped (3" I/O)
Ford Racing Nodular Iron Flywheel
Centerforce Clutch
Ford Racing driveshaft
fully built posi rear end with 4.10s, 31 spline, blah blah blah
OEM coils
NGK-R plugs
Fully custom fuel system - e-85
Rice_slayer
Nothing special here, very mild boost Mach 1, car ran out of fuel, more power is there but need to add a BAP, only pushed it to 6k on 6#s. Mods are as follows:
Termy fuel pumps (no wire upgrade or BAP)
Procharger P1SC with 8lb pulley
VMP slot style MAF conversion
39# injectors
BBK longtubes
BBK o/r X pipe, Borla stinger catback.
Witzy0070
Montana
From the previous owner. Going to install methanol and some 4.10 gears this Winter and get re-tuned. Torque seems a bit on the low side?
Aray176
