what else with coil overs
brian95
indiana
i have a coilover kit for front and im just trying to make sure i dont need anything else to install this is what i have
upr coilover kit with k member and adj a arms
caster camber plates
strange struts
upr steering bolts for use with aftermarket k members
2 spanner wrenches
flaming river manual rack setup
Did the coil over kit come with springs?
If so, then I believe you have everything. Just remember to get a proper alignment afterwards.
ProKiller
PA
does the manual rack come with tie rod ends? does the a-arms come with ball joints? otherwise the only other thing i can think of is motor mounts. get new ones while you're in there.
RabidPony
Canton, MI
x2 Change out all the sphericals and the motor mounts while you're in there. Might not hurt to replace the transmission mount while you're at it.
brian95
brian95
indiana
i forgot to add new upr solid mounts and steering has new tie rods and also have new shaft. i think the a arms has new ball joints but i will check them havnt took them out of boxes
peasant99
