Won’t Start No Fuel Pressure No Spark
HuntStratt
Hi all, recently I was driving my car 95 Gt and during the drive the engine sputtered and died and wouldn’t start back up again. I have no fuel pressure and no spark and so far I’ve replaced the fuel pump, coil, checked plugs (clean, replaced a few months ago along with wires) and still nothing. Fuel pump primes I can hear it upon key turn on. I checked pressure at the valve under the hood and there’s no pressure there. Not sure what could cause both to go bad at once like this.
Interesting. My guess would be fuel line from the pump inside the tank. No clue about the no spart. Someone will chime in. Surely something like this has happened to someone.
You say you have no fuel psi
But you hear the pump turning
How did you check to see if you have fuel at the rails
Well start with fuel first
Could be a relay or fuse
Or plugged up line in tank
You would need to put a fuel psi Guage on the rail to test for fuel flow
RevBott
