Wondering if stock flywheel and Mcleod Super StreetPro clutch kit are compatible MCL-75205 1995 GT
garrisonsheff
I'm new to specing out a clutch and was wondering if anyone would be able to help me know if this clutch kit is compatible with the original flywheel on the '95 GT or if I will need to purchase a different flywheel as well. I'd like to just resurface the original flywheel and use that when I replace the clutch since mine is beginning to go out. I was looking at this specific model clutch kit MCL-75205 because down the road I want to install an On3 turbo kit and want a clutch that will be able to support those power numbers that it'll put out.
Musturd
Yes . I run a street extreme pro behind a stock replacement flywheel
G
garrisonsheff
Alright, so it seems that model is the same kind of thing but more aggressive. So in theory this one I want should work as well. Thanks.
Musturd
Yea I’m running one a step or two above the one you mentioned .
G
garrisonsheff
How do you like it in general? Is it a lot harder to drive compared to stock? And have you put a lot of miles on it?
Musturd
Oh they’re softer then stock or the same but grab and hold power way better . I love mine .
Suprasuavy
