X pipe differences
apsmith49921
apsmith49921
Have you popped the eliminators off and checked for any loose connections or damages? I haven't had an issue with mine yet. But for 12 bucks the solder quality could be comprised
Sent from my SM-G955U using Tapatalk
white95
Apex Junky
Admin
Prairieville, LA
so right now I have BBK O/R X-pipe into shortened stock flow tubes into 24" 2.25" Thrush glasspacks, into turndown tips before the axle. I am thinking about putting the Walker flow tubes back on with a pair of these https://www.ebay.com/itm/Pair-of-Si...Muffler-FULL-BOAR-O-O-2-25-FB430/200908062454 and hooking those<<< to the OEM tail pipes. That should be quieter than dumped glass packs right?
That’s a copy of the Flowdisaster 10 series. It will still be loud and will drone. It’ll just be more or less directed towards the poor bastards behind you :)
dwcopple
Not yet. But only 1 lined up properly. The other side needed the tit trimmed off to snap together.
apsmith49921
apsmith49921
That's strange could be a loose connection that rattled free too I suppose
dwcopple
Not sure, I'll look when I start messing with the exhaust. I'm taking it in Saturday for them to install the subframe connectors on Monday AM.
DKblue98GT
I had the MIL eliminators from LMR but I still had to zip tie them together or I would get a code...
dwcopple
that's interesting ^^^. The seller refunded me on eBay so I'll mess with them a bit. I ordered the Jones Full Boar single chamber muffler pair yesterday. I also did some cleanup on the OEM tailpipe tips to get them as shiny as possible again. They are in great shape. I hope I can adapt them back on easily. There's not much pipe before they start to bend upwards to clear the axle and I want to clamp them on for now. I will have them welded to the extension pieces I adapt on once the whole system is pieced together. If anyone is interested in 2 24" Thrush glasspacks with turndown tips in 2.25" with less than 500 miles on them, they will be up for grabs.
Srchop16
