$45 dollar sequential taillights.
<blockquote data-quote="robb15033" data-source="post: 963257" data-attributes="member: 13109"><p>I also just remembered from years ago that the LED bulbs had to be pluged in a certain way to operate correctly. If they act retarted, then unplug, spin bulb around and plug in that way.</p><p>Did you get your sequential turn signal relay yet? autotrix.com has them and AM sells a Raxiom version. Got mine from autotrix a while ago. Those are the only two places I know of to get one to control the slower flash rate while turn signal is on. Either way, if LED's are used, then the load resistors are needed.</p></blockquote><p></p>
[QUOTE="robb15033, post: 963257, member: 13109"] I also just remembered from years ago that the LED bulbs had to be pluged in a certain way to operate correctly. If they act retarted, then unplug, spin bulb around and plug in that way. Did you get your sequential turn signal relay yet? autotrix.com has them and AM sells a Raxiom version. Got mine from autotrix a while ago. Those are the only two places I know of to get one to control the slower flash rate while turn signal is on. Either way, if LED's are used, then the load resistors are needed. [/QUOTE]
Latest: MasterDot
Today at 12:31 AM
Today at 12:11 AM
Latest: Daryl
Yesterday at 9:22 PM
New Member from Virginia
Latest: Daryl
Yesterday at 8:55 PM
TKX shifter position
Latest: dsrtjeeper
Yesterday at 2:54 PM
TTSaleen
