.550 Valve Springs
YesA2Valve
Wanting to run the summit e303+ cam with 1.6 rockers, the cam is .550/.540 lift and I’m wondering what valve springs would be the best if anyone had links to any.
RAU03MACH
NEW MEXICO
also keep in mind it changes the push rods as well may be shorter or longer
there is a tool to check that
HOURSEBLACK
Valve springs must have enough pressure to prevent the valve from "flattening" or losing its return force, especially with such high lift. For .550"/.540" lift, you will need springs with moderate to high return pressure.
Pabbblo91
If you're planning to run the Summit E303+ cam with 1.6 rockers, and you’re aiming for a .550/.540 lift, choosing the right valve springs is crucial for maximizing performance and ensuring your engine runs efficiently. The right springs will prevent valve float at higher RPMs and maintain optimal power output, so it’s essential to pick springs that complement your camshaft’s specs. For racing or high-performance builds, Supertech provides superior valve train components, including valves and valve springs, designed for virtually every type of motorsport pistons. Whether you're into Drag Racing, Rally, Road Racing, or building a powerful street engine, Supertech offers high-quality solutions tailored to your needs. They have a wide selection of valve springs that can handle high lift cams and increased RPMs, and if you need something more specific, Supertech is ready to custom-manufacture the perfect solution for you.
