Brakes leaking....bad
<blockquote data-quote="uncltrvlnmatt" data-source="post: 553298" data-attributes="member: 8290"><p>DON'T DRIVE IT!!!!!!</p><p></p><p>Like Chris said, probably a leak at the crush washer, or you could have overtightened the banjo bolt and it has just now cracked due to the stress.</p><p></p><p>I would replace both lines, banjo bolts, and crush washers. Make sure the area where the washer sits is clean. If you have dirt under the copper washer it will not seal properly and leak.</p></blockquote><p></p>
[QUOTE="uncltrvlnmatt, post: 553298, member: 8290"] DON'T DRIVE IT!!!!!! Like Chris said, probably a leak at the crush washer, or you could have overtightened the banjo bolt and it has just now cracked due to the stress. I would replace both lines, banjo bolts, and crush washers. Make sure the area where the washer sits is clean. If you have dirt under the copper washer it will not seal properly and leak. [/QUOTE]
C
Latest: chasingomas
Today at 1:05 AM
Build Ups & Projects
Latest: NEW EDG
Yesterday at 8:48 PM
Latest: Slice
Yesterday at 8:34 PM
Exterior and Interior
A
Latest: Armand
Yesterday at 8:32 PM
V6/GT rear spoiler 94/95?
Latest: Slice
Yesterday at 8:30 PM
Daryl
GTamas
