Engine Specific Tech
Exhaust lambda value too high
<blockquote data-quote="GTamas" data-source="post: 1547963" data-attributes="member: 30240"><p>So, finally some results. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p>I replaced the spark plugs, plug wires, EGR, mufflers and sealed the leak at the TPS. With the AIR pump, all the emissions values are okay, but 1,7 lambda lean reading. Unplugging the vacuum from the AIR bypass valve (so bypassing the airflow), the lambda value is down to below 1,03, but the HC values rise above limits. This is with warmed up engine and cats.</p><p></p><p>I was able to convince the inspector, that this is normal and the 1,7 lambda is no problem for the emissions test therefore. So I finally passed all tests!! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>BIG THANK YOU to everyone for your good advice!</p></blockquote><p></p>
[QUOTE="GTamas, post: 1547963, member: 30240"] So, finally some results. :) I replaced the spark plugs, plug wires, EGR, mufflers and sealed the leak at the TPS. With the AIR pump, all the emissions values are okay, but 1,7 lambda lean reading. Unplugging the vacuum from the AIR bypass valve (so bypassing the airflow), the lambda value is down to below 1,03, but the HC values rise above limits. This is with warmed up engine and cats. I was able to convince the inspector, that this is normal and the 1,7 lambda is no problem for the emissions test therefore. So I finally passed all tests!! :) BIG THANK YOU to everyone for your good advice! [/QUOTE]
96blak54 2001 Cobra
Latest: white95
Today at 12:22 AM
Build Ups & Projects
Latest: ttocs
Today at 12:17 AM
C
Latest: chasingomas
Yesterday at 11:38 PM
Latest: SsgDoc94
Yesterday at 7:44 PM
Latest: 96blak54
Yesterday at 5:39 PM
96-04 - 4V Specific
Jerry santos
GTamas
