help! car overflow tank smokeing / strong coolant smell running hot/ air bubbles.
<blockquote data-quote="Twista" data-source="post: 1075564" data-attributes="member: 8202"><p>Crap, dont forgot to check the overflow bottle. Make sure its @ the hot level after you get down burping the cooling system. Once you drive it after the 1st drive check the overflow bottle again because the engine mightve sucked the bottle clean.. if so add more to the overflow tank to the full mark if car is warmed up.</p></blockquote><p></p>
[QUOTE="Twista, post: 1075564, member: 8202"] Crap, dont forgot to check the overflow bottle. Make sure its @ the hot level after you get down burping the cooling system. Once you drive it after the 1st drive check the overflow bottle again because the engine mightve sucked the bottle clean.. if so add more to the overflow tank to the full mark if car is warmed up. [/QUOTE]
New Member from Canada
Latest: Drhoward
38 minutes ago
96blak54 2001 Cobra
Latest: white95
Today at 11:27 AM
Build Ups & Projects
Wheel and tire specs?
Today at 11:01 AM
Suspension and Brakes
A
Latest: Armand
Today at 10:19 AM
Missing cover behind flywheel
Latest: 96blak54
Today at 9:19 AM
96-04 - 2V Specific
Musturd
ju015dd
shovel
