TECH
Forced Induction & Tuning
injectors for boost
<blockquote data-quote="SVTurbo 98" data-source="post: 611730" data-attributes="member: 11761"><p>With the use of an fmu you can get away with more power on undersized injectors. But like I said, it is near impossible to get a good tune with because of the inconsistancy of the fmu. It would be ideal to buy properly sized injectors for the application, ditch the fmu and hack into the ecm for proper tuning. In the article they aren't doing any tuning. They're just bolting crap on and hoping to trick the ecm. A "calibrated" maf isn't needed if you install the proper transfer function in the tune. Also tuning a car with "big" injectors isn't a problem if the tuner knows wtf he is doing. Good luck</p></blockquote><p></p>
[QUOTE="SVTurbo 98, post: 611730, member: 11761"] With the use of an fmu you can get away with more power on undersized injectors. But like I said, it is near impossible to get a good tune with because of the inconsistancy of the fmu. It would be ideal to buy properly sized injectors for the application, ditch the fmu and hack into the ecm for proper tuning. In the article they aren't doing any tuning. They're just bolting crap on and hoping to trick the ecm. A "calibrated" maf isn't needed if you install the proper transfer function in the tune. Also tuning a car with "big" injectors isn't a problem if the tuner knows wtf he is doing. Good luck [/QUOTE]
Latest: ttocs
54 minutes ago
General Tech
Today at 1:05 AM
Yesterday at 7:31 PM
Latest: Mustang5L5
Yesterday at 7:11 PM
Lowering spring issue
Latest: 95Five0
Yesterday at 6:39 PM
shovel
GTamas
TECH
injectors for boost
