TECH
Suspension and Brakes
painted calipers
<blockquote data-quote="94Pro-5.0" data-source="post: 346263" data-attributes="member: 9787"><p>also, don't put the paint on too thick. The calipers get hot, so if you put on too many coats it will crack, even if you use high temp paint. powder coating is the way to go, but if you can't afford it, this is how i'd do it</p><p></p><p>sand with 80, then 180. This will make it coarse so the paint will stick.</p><p>sand the first coat barely with 320.</p><p></p><p>put on 2 more light coats</p><p></p><p>then, like handz said, sand off the paint on the letters (if you have the letters) and you could even put a thin coat of high temp clear over that.</p></blockquote><p></p>
[QUOTE="94Pro-5.0, post: 346263, member: 9787"] also, don't put the paint on too thick. The calipers get hot, so if you put on too many coats it will crack, even if you use high temp paint. powder coating is the way to go, but if you can't afford it, this is how i'd do it sand with 80, then 180. This will make it coarse so the paint will stick. sand the first coat barely with 320. put on 2 more light coats then, like handz said, sand off the paint on the letters (if you have the letters) and you could even put a thin coat of high temp clear over that. [/QUOTE]
K
Missing cover behind flywheel
Latest: kristio
3 minutes ago
96-04 - 2V Specific
Car miss firing under load
Latest: 96blak54
26 minutes ago
General Tech
96blak54 2001 Cobra
Latest: Snorky
Today at 6:49 AM
Build Ups & Projects
Wheel and tire specs?
Latest: badass98svt
Today at 6:45 AM
C
Latest: chasingomas
Today at 1:05 AM
kristio
joemomma
TECH
painted calipers
