Engine Specific Tech
96-04 - 2V Specific
Please help me out with cams
<blockquote data-quote="tekcisGT" data-source="post: 694832" data-attributes="member: 12148"><p>Yes Droptop, PLEASE! I think it will no doubt be interesting either way.</p><p></p><p>Duffdaddy, every cam test ive seen including cam masters (unbiased comp vs comp shootout) shows the 270 to be only 5hp more up top and marginal loses in the lower on tq. It is my belief that the 270 needs ported heads to shine, as the tests showed. Stage 1 cams get almost every bit as a stage 2 in most cases with stock heads and no loss in torque down low. This has been the case everywhere I have looked unless were talking hitech stage 2, which is probably the best proven cam out there. Too bad it wont fit w/o taking the heads off and notching or valve grindin...this is Hitechs advice.</p></blockquote><p></p>
[QUOTE="tekcisGT, post: 694832, member: 12148"] Yes Droptop, PLEASE! I think it will no doubt be interesting either way. Duffdaddy, every cam test ive seen including cam masters (unbiased comp vs comp shootout) shows the 270 to be only 5hp more up top and marginal loses in the lower on tq. It is my belief that the 270 needs ported heads to shine, as the tests showed. Stage 1 cams get almost every bit as a stage 2 in most cases with stock heads and no loss in torque down low. This has been the case everywhere I have looked unless were talking hitech stage 2, which is probably the best proven cam out there. Too bad it wont fit w/o taking the heads off and notching or valve grindin...this is Hitechs advice. [/QUOTE]
Latest: wmfateam
10 minutes ago
New guy from WA state
Latest: Ronnied
Today at 12:28 PM
Latest: wmfateam
Today at 11:49 AM
What lb radiator cap 347 sbf
Latest: Mustang5L5
Today at 10:32 AM
Big 4 piston caliper, "genisis brembo, 13in brake upgrade adventure
Latest: Mustang5L5
Today at 10:28 AM
Suspension and Brakes
96GTPlanB
wmfateam
ironhorsewayne
GTamas
96-04 - 2V Specific
