Should This worry me?
<blockquote data-quote="vermilion" data-source="post: 639910" data-attributes="member: 9891"><p>aluminum pits. gray powder residue which is a form of corrosion. depending on thickness of aluminum and damage of pitting, you can lightly sand and treat it without issues. prime and rust-preventative paint. aluminum mostly pits due to long term moisture,air, electrolytes. dissimilar metals also cause this issue. IE. steel fasteners on aluminum base metals... again to OP, sand, clean, prep, prime, paint.</p></blockquote><p></p>
[QUOTE="vermilion, post: 639910, member: 9891"] aluminum pits. gray powder residue which is a form of corrosion. depending on thickness of aluminum and damage of pitting, you can lightly sand and treat it without issues. prime and rust-preventative paint. aluminum mostly pits due to long term moisture,air, electrolytes. dissimilar metals also cause this issue. IE. steel fasteners on aluminum base metals... again to OP, sand, clean, prep, prime, paint. [/QUOTE]
Today at 7:35 PM
Latest: MasterDot
Today at 5:59 PM
Latest: 07GtS197
Today at 3:56 PM
TKX shifter position
Latest: dsrtjeeper
Today at 2:54 PM
EFI to Carb conversion- Mods Sticky please
Today at 12:15 PM
weendoggy
ju015dd
Sparty443
