TECH
Electrical & Stereo
Too much power???
<blockquote data-quote="Pshull727" data-source="post: 830637" data-attributes="member: 12651"><p>ok guys the way alpine and most other brands rates amps at 14.4 volts so with that amp you would be able to get 500 rms at 14.4 volts now most cars run arounf 13.5-13.8 volts when warmed up. Also if you have now power upgades you cant stay at a high voltage. So yes with the right tuning the amp will work great on the subs. And for a fuse i would run a 60 or 80 amp fuse.</p></blockquote><p></p>
[QUOTE="Pshull727, post: 830637, member: 12651"] ok guys the way alpine and most other brands rates amps at 14.4 volts so with that amp you would be able to get 500 rms at 14.4 volts now most cars run arounf 13.5-13.8 volts when warmed up. Also if you have now power upgades you cant stay at a high voltage. So yes with the right tuning the amp will work great on the subs. And for a fuse i would run a 60 or 80 amp fuse. [/QUOTE]
I
Latest: ironhorsewayne
45 minutes ago
Build Ups & Projects
New guy from WA state
Latest: Ronnied
Today at 4:26 PM
G
94 gt 351w swap
Latest: greenhorn4311
Today at 4:06 PM
Engine Swap
Latest: Snorky
Today at 3:04 PM
Latest: wmfateam
Today at 2:43 PM
96GTPlanB
shovel
TECH
Electrical & Stereo
Too much power???
