Engine Specific Tech
vac leak?
<blockquote data-quote="toyman" data-source="post: 760950" data-attributes="member: 10841"><p>Loss of power can be caused by different things. Possible vacuum leak as mentioned and a dirty MAF or clogged filters (air & fuel). There are other variables but I would check these first. If you don't know when the air and fuel filters were changed, then just change them. The MAF element should be cleaned with MAF or electrical contact cleaner. Just spray on liberally. The vacuum leak is a little harder to find as hoses & fittings are not always visible. The best way is a smoke test but you will have to have a shop do that for you.</p></blockquote><p></p>
[QUOTE="toyman, post: 760950, member: 10841"] Loss of power can be caused by different things. Possible vacuum leak as mentioned and a dirty MAF or clogged filters (air & fuel). There are other variables but I would check these first. If you don't know when the air and fuel filters were changed, then just change them. The MAF element should be cleaned with MAF or electrical contact cleaner. Just spray on liberally. The vacuum leak is a little harder to find as hoses & fittings are not always visible. The best way is a smoke test but you will have to have a shop do that for you. [/QUOTE]
Latest: MasterDot
25 minutes ago
Latest: 07GtS197
Today at 3:56 PM
TKX shifter position
Latest: dsrtjeeper
Today at 2:54 PM
EFI to Carb conversion- Mods Sticky please
Today at 12:15 PM
You can fit a carb or TBI under the stock SN95 hood.
Today at 12:06 PM
chasingomas
07GtS197
shovel
vac leak?
