Engine Specific Tech
Vibration
<blockquote data-quote="5litrarag" data-source="post: 863124" data-attributes="member: 9863"><p>If it does it regardless of whether its in gear or not, its a problem on the motor itself. Look closely and see if one or both of the mounts have collapsed. You should be able to see a good amount of the dampening material sandwiched in between the mount plates. It shouldnt look like its being squeezed, just a thick piece of rubber thats about an inch thick. If the mounts look good, I guess its time to see if there is a problem on the flywheel side.</p></blockquote><p></p>
[QUOTE="5litrarag, post: 863124, member: 9863"] If it does it regardless of whether its in gear or not, its a problem on the motor itself. Look closely and see if one or both of the mounts have collapsed. You should be able to see a good amount of the dampening material sandwiched in between the mount plates. It shouldnt look like its being squeezed, just a thick piece of rubber thats about an inch thick. If the mounts look good, I guess its time to see if there is a problem on the flywheel side. [/QUOTE]
Latest: GTamas
Today at 2:10 AM
Latest: 07GtS197
Yesterday at 8:18 PM
G
Ford Carlisle
Latest: gatorblue92
Yesterday at 6:34 PM
V6/GT rear spoiler 94/95?
Yesterday at 1:56 PM
Exterior and Interior
Latest: SPeace-ATL
Yesterday at 1:51 PM
tmwsccsh
Vibration
