Weird Sound
<blockquote data-quote="GDTrumbo" data-source="post: 607689" data-attributes="member: 10665"><p>You can't really "not" put the clips back in. As I remember the clips are riveted to the clutch fork. They can get weak with age though. If the TOB fits loose in the clips, it can dance around on the TOB retainer when realeased. Especially if the retainer is worn as well.</p><p></p><p> As for the pivot ball, it can rattle if the cable is adjusted too loosely and the pivot ball is dry of grease. </p><p></p><p> If I ever have to replace the clutch in mine, it will include:</p><p></p><p>Flywheel machining/replace</p><p>Clutch disc</p><p>Pressure plate</p><p>FRPP TOB</p><p>FRPP "needle" style pilot bearing</p><p>Cobra "steel" TOB retainer</p><p>Hardened Cobra input shaft - if necessary</p><p>FRPP fork assembly</p><p>Lube pivot ball w/ synthetic grease</p><p></p><p>GT</p></blockquote><p></p>
[QUOTE="GDTrumbo, post: 607689, member: 10665"] You can't really "not" put the clips back in. As I remember the clips are riveted to the clutch fork. They can get weak with age though. If the TOB fits loose in the clips, it can dance around on the TOB retainer when realeased. Especially if the retainer is worn as well. As for the pivot ball, it can rattle if the cable is adjusted too loosely and the pivot ball is dry of grease. If I ever have to replace the clutch in mine, it will include: Flywheel machining/replace Clutch disc Pressure plate FRPP TOB FRPP "needle" style pilot bearing Cobra "steel" TOB retainer Hardened Cobra input shaft - if necessary FRPP fork assembly Lube pivot ball w/ synthetic grease GT [/QUOTE]
Latest: 07GtS197
Today at 3:56 PM
TKX shifter position
Latest: dsrtjeeper
Today at 2:54 PM
Latest: ttocs
Today at 1:40 PM
EFI to Carb conversion- Mods Sticky please
Today at 12:15 PM
You can fit a carb or TBI under the stock SN95 hood.
Today at 12:06 PM
shovel
Weird Sound
