1996-1998 4v engine
98'Coco'GtVert
Im on the hunt for a full cobra engine preferably a 96-98 because i have a 98gt, just wanna know guys can you help me out?
Sent from my SM-G955U using Tapatalk
white95
Apex Junky
Admin
Prairieville, LA
I have a nicely built C-head 4V in Louisiana with zero run time I’d sell but it’ll cost ya at least $4k
white95
Apex Junky
Admin
Prairieville, LA
What exactly do you have done to this motor White95
Teksid block, painted black
10.45:1 Diamond 30012 pistons
Total Seal AP SS rings
Boss 302 rods
Clevite H-series rod bearings
Kellogg crank
Clevite H-series crank bearings
Boundary Billet 3V/GT500 oil pump
ARP fasteners throughout
MMR oil pan
2003 Cobra heads [rebuilt]
2003 Cobra cams
Wonder Racing head cooling mod
Mach 1 intake
stock throttle body
JLT cold air intake
Coil on plug conversion
The bottom end is good for about 750 whp but others have pushed the Boss 302 rods further.
88stang88
Professional Lurker
Granite City, IL
Boss 302 rods
Kellogg crank
MMR oil pan
2003 Cobra cams
Mach 1 intake
stock throttle body
JLT cold air intake
So its a supercharger away from being a terminator setup.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Better than a terminator setup. The pistons are deck height for a tighter squish, the rods are lighter for faster revs, and the block is aluminum so it’s lighter from the get go. And @white95, you can’t forget those high dollar custom cometic head gaskets.
88stang88
Professional Lurker
Granite City, IL
I am still learning the in's and out's of the 4v life.
88stang88
Professional Lurker
Granite City, IL
I am going to get a Mark VIII 4.6 4V tomorrow for $400. So I will be learning a lot on my own quickly. I will definitely try to utilize all the knowledge here that is available. Have a pretty good performance shop machinist down the road too. Tap his brain might be good for me also.
98'Coco'GtVert
Oh yeah startin from the bottom is a good way to piece things together & learn as well how everything goes & does its own job
white95
Apex Junky
Admin
Prairieville, LA
It has a ton of potential.
That’s true. You also set the rings for about 20 psi and I forgot the 3V windage tray.
chris84svo
Check prestige mustang or MPS auto salvage, they have a ton of an 95 stuff and have had good luck in the past getting parts from both places
Chivo Viejo
