any questions about air suspension..i can answer :)
whiplash473
Northern IL
i'm no expert on c/o's but are they all exactly the same? i mean is it impossible for onyx to have a different setup?
Tony
Tony
ohio
[video=youtube;S34KmnCGRIA]http://www.youtube.com/watch?feature=player_detailpage&v=S34KmnCGRIA[/video]
are mustang coilovers different? idk, this is the only c/o's ive ever used, lol.
and the thread is about fuukin bags, lolol. onyx just enjoys a good debate when he see's an opening, lol.
whiplash473
Northern IL
lol Tony yes I'm sure, the stuff in that vid is irrelevant. here is what mine looked like before install, all it takes is turning the bottom collar.
Tony
Tony
ohio
those look cool. if only you did'nt need to remove all 4 wheels, break out the micrometer and a spanner, lol. but yea...i assumed your coilovers had the same adjustments as ones i've had.
either way bags are still way more versatile than c/o's.
You can adjust the collars with your hands, you just need to loosen the set screw. You may be able to do it without removing your wheels depending on the height and wheel, etc. Also it's easy to keep even because I just adjust them a full turn at a time so you just measure both sides quick and you're good to go.
i will never argue that bags are easier to adjust, that would be silly. It's awesome that it gives you the super low stance but also the ability to drive over pesky bumps and shit.
Superman3872
