April ROTM - Voting
Status
Not open for further replies.
Orange 94
Alberta Canada
Time to vote for April Rotm!
Nominees:
03DSGGT
the5.ohh
Will
03DSGGT
Thanks guys, its an honor to be nominated! I appreciate those of you that think that its ROTM material.
Little back story on the car. I bought it on a whim in 2005 bone stock, save for '03 Cobra seats. Over the years it has gone through a few different transformations. Right now, the car has an N/A street/strip setup. The fastest that I have ever been with the car was 12.4 @ 116 with 325rwhp. The car now has 350rwhp, and shooting for more after the tune with the Edelbrock intake and 6061 plenum. Here is a rundown of mods:
Ill try to keep this as simple as possible lol:
Engine/under hood/ECU :
Stock 2003 Romeo short block
3V windage tray
Canton road race oil pan
4V oil pump/ pick up
Trick Flow 38cc heads (10.3:1 C.R.)
GT40 cam followers
GT40 lash adjusters
CMS stage 3 N/A cams (.560/.560 238* 244* 109LSA)
Trick Flow cam bolts/ MMR billet cam gear spacers
Trick Flow cast aluminum valve covers (painted FRPP blue)
Stewart Warner EMP high flow water pump
Steeda UDPs
A/C belt bypass mod
Edelbrock Victor Jr intake manifold
6061 intake plenum
SVE 75mm throttle body
ARP 12pt stainless hardware on the intake and intake components
JLT CAI
FRPP 30# injectors/SVT Focus pump
Valve covers routed to Moroso catch can (fitting welded on pass. side cover)
03/04 Cobra radiator
MAC ceramic longtubes
BBK O/R H pipe/BBK O/R X pipe
MAC Pro Dump exhaust
Dumped Magnaflow Race Bullets
Borla Catback exhaust
Flowmaster Super 44 home made cat back
MSD 2 step
Dyno tuned with SCT software by Street Lethal Performance
350rwhp/347rwtq before the Edelbrock swap
Drivetrain:
2002 Tremec 3650 5 speed
Tremec TSB upgrade
FRPP billet steel flywheel
ARP flywheel bolts
Centerforce DF clutch
ARP clutch bolts
FRPP TOB
OEM cable
MM quadrant
Fiore firewall adjuster
Stifflers driveshaft loop
MGW shifter
FRPP aluminum driveshaft
Spicer non greaseable U joints
FRPP 4.30 gears
Strange 31 spline axles
FRPP 31 spline carrier
Moroso 3" wheel studs front and rear
CHE Track Attack brace with multiple LCA mounting points
Trick Flow rear and cover/girdle
Chassis/wheels/tires:
MM FLSFCs
UPR upper and lower torque box plate kit bolted and welded
MM 6 point roll bar with swing outs
18x9/10 Anthracite Bullitts
BFG KDW 265/35 and 295/35 tires (street)
17x4.5 Race Star front wheels/ 15x8 (5.5 B.S.) Race Star rear wheels
255/55/17 M&H front radials/ 26x10-15 MT stiffwall slicks with tubes (strip)
Bullitt front brakes with stainless hoses/ FRPP Cobra rear brake kit
Fox body 4 cylinder front springs
Tokico 5 way drag struts
No front swaybar
MM caster camber plates
UPR extreme bumpsteer kit
03/04 Cobra steering shaft
Steeda X2 balljoints
Team Z 94-04 stock location rear drag springs (with 1" Global West spacer)
Strange 10 way adjustable fox body rear shocks
Team Z Street Beast LCAs (IC set up with rear axle brace)
Baseline relocated UCA kit
Baseline Race anti roll bar
Interior:
03/04 Cobra seats
Simco gauge cluster
SOS gauge pillar
Auto Meter Lunar water and oil pressure gauges
Raptor shift light hidden in the A/C vent
Bullitt shift ball
Bullitt/Mach pedal covers
03/04 Cobra E brake handle
03/04 Cobra steering wheel
ACC "GT" floor mats
UPR billet lock posts and bezels (painted to match IUP)
Door cups mainted to match silver radio bezel (IUP package)
Exterior:
99/01 Cobra front bumper
03/04 Cobra chin lip
8000K Bi Xenon HID headlight conversion
3000K HID fog light conversion
H.O. Fibertrends 2.5" cowl hood
Billet hoodpins
Shorty antenna
UPR wiper deletes painted satin black
V6/Mach running horse fender emblems
03/04 Cobra side mirrors
03/04 Cobra side skirts/01 Bullitt side skirts going on soon
01 Bullitt side scoops
Bullitt/Mach C pillars and quarter glass
V6 spoilerless trunk lid
99-01 Cobra tail lights
the5.ohh
First off, thanks a bunch for nominating me! Long story short! Got the car at 16 in 2012, bone stock, automatic.. 3 years later I have been through so much with it.. I could've had a Terminator or Mach 1 with the money I put in it, but I love it!
Mods:
Exterior-
1999-04 GT Badges
Tinted 3rd Brake Light & Rear Sidemarkers
Stainless Steel bumper inserts
Kaenen S281 Wing
Body colored mirrors
Cobra Bumper
Trufiber 3" Cowl Hood
20% Tint
Black Vinyl over the rear dot matrix
Clear Cobra Headlights & Sidemarkers
Yellow Fogs
Wheels-
18x9, 18x10 Silver Saleens
Continental Extreme Contact DW Tires
255/40/18, 295/35/18
Drivetrain-
5 speed swapped!
Upgraded T5
RAM HDX Clutch
Ford Racing Aluminum D/S
Ford Racing 3.55 Gears
MGW short throw shifter
MaxMotorsports Aluminum clutch quadrant & firewall adjuster
Suspension-
Ford B Springs
KYB shocks and struts (Bilsteins going on)
J&M Rear Upper & Lower Control Arms
Ford Racing Rear Upper Axle Bushings
Poly Front Swaybar Endlink Bushings
Interior-
Bullitt Pedals
Redlinegoods Leather Shift Boot
Coyote Style 5 speed shift knob
Motor & Exhaust
C&L Ram Air Intake, 76mm maf
BBK 70mm tb
Smog pump delete pulley
Mac longtubes, Mac shorty offroad H
Borla Stinger S type mufflers
3.5" Magnaflow tips
Will
This is my car a 1994 Mustang GT. It’s been my first and only Mustang. It belonged to my older cousin who I was very close with and sadly he lost his life back in 2009 in a car accident. When I found out he wanted me to have this car I decided to restore it back to its former glory. Here is a little background on the car. He bought it back in 1999 with 53k miles on it. As a young kid whenever I would travel to Washington for family gatherings for the holidays I would get to go cruising in it. Basically, I felt like the coolest person on the planet and I wanted one just like it. But he moved on to bigger and “faster” things and the car got parked in the driveway from 2003 to 2010. I almost bought it from him when I was 16 but I couldn’t afford the insurance, I almost bought it from him again in 2007 but I couldn’t afford what he was asking for it and it needed some work. I found out after he passed that he was planning on giving me the car and I received it in 2010. I felt it was my duty to restore it because it was looking pretty sad after sitting for so long in the Washington elements.
When I got the car it had 94k miles on it and the interior was in pretty good shape. The engine bay was pretty dusty put was in pretty good shape as well. The paint was starting to peel off and it hadn’t had a bath in who knows how long. I sold my 1998 VW GTI VR6 that was my first car to put together some money to get it back on the road. The very first thing I did was changed all the fluids and get it started. Luckily all it needed was a new battery to get started. The car didn’t feel like it had much power and the check engine light get coming on. I checked the codes and it said it was running lean. I bought some new oxygen sensors from Ford and it ran perfectly. Here is a list of things I have done on the car.
Detail work:
- Upper engine bay professionally washed and dressed.
- The Interior professionally shampooed and dressed.
Engine Maintenance:
- All the fluids changed
- New Radiator and thermostat
- New radiator cover decal
- K&N air filter.
- New battery
- MSD distributor cap with
- NGK G power platinum spark plugs
- OEM distributor wires with new coil
- Sanded and painted coil bracket
- Ford OEM Oxygen sensors
- New Adjustable Clutch Cable with Billet Quadrant
Suspension:
- Maximum Motorsports caster camber plates (already on car)
- Crossed drilled and slotted Rotors (already on car)
- H&R lowering springs (already on car)
- New monroe sensa trac shocks and struts
- New rear Cobra sway bar
Exterior:
- New Paint professionally sprayed. I kept the original black and buffed and waxed.
- Removed hood pins & filled holes
- Repaired stress cracks in front bumper
- Repaired dents
- New Coyote 5.0 badges and emblems
- Stainless steel bumper letter inserts.
- New headlights
- New taillights
- New reflector lenses
Interior:
- Windows tinted (already on car)
- New dash clock
Drivetrain:
-FRPP 3.55 gears (already on car)
-Rear differential fluid changed with gasket
Exhaust:
- BBK high flow catted x pipe
- Flowmaster super 44 series muffles
- 3 inch tail pipes
Wheels:
-17X8 OEM Tribar’s (Current)
-17x8 Bullitt’s
-17x8 94 Cobras (sold)
turion94
I just want to say thank you! It's an honor just being considered among these worthy members.
Sinned83
MA
Joe and Will you guys are worthy, clean rides with tasteful mods But Chris has killed it with this build I love the cobra bumper, tails and engine work. Im really felling this car. Id vote for it versus anyone right now. Chris you interested in trades?
Michael Plummer
Brockton, MA
Yes, it is cool to be nominated among your peers for your work and end product up until now. Three good cars but there can only be one ROTM winner.
03DSGGT: 116mph in the quarter mile? Get the "F" out of here.....that is flying. Mods, more mods and even more mods. I didn't think your mods list was going to stop. Beautiful car, simply beautiful.
The5.ohh: At 16 I didn't have the maturity you have to own a car like that. Amazing job bringing your car to the level it currently sits and it must of been hard on limited funds. Great job.
Will: Great story and a great save for a Mustang that was deteriorating fast. I was impressed with the attention to detail that went into returning your car back to it's original look. Great job.
My vote is in.
03DSGGT
SN95 Supporting Member
Akron, Ohio
Thanks for all of the kind words fellas. I've put a ton of work and money into the car over the years, and right when I think I'm at a good place with it I get more ideas popping into my head lol. It means a lot that you guys appreciate the hard work.
turion94
03DSGGT: 116mph in the quarter mile? Get the "F" out of here.....that is flying. Mods, more mods and even more mods. I didn't think you mods list was going to stop. Beautiful car, simply beautiful.
My vote is in.
I've always been a little weird in the fact that I like getting into an older car and feeling like you are in a time capsule. You really get the sense of what the car was like back in that time period. It was a different time in America back in 1994. This car is special to me because of the history I have with it. The direction of the car I wanted to take with it wasn't your typical Mustang that you put a ton on modification and $ into. Yeah, it might not attract mass numbers of people but I find enjoyment out of the simplicity of it. It drives wonderful and when you think about a stock GT you think there's nothing special about them. But, you really get a sense driving around and never seeing another on the road like you. Clean stock early SN95 Mustangs are becoming an endangered species. I always pass Mustangs in my area that have a ton of modifications done to them. I rarely pass an older one that looks like it just drove off the dealer lot.
I do love modified cars, whether they are classic muscle, or new school domestic/imports. I have a passion for cars and appreciate the art and individualism that goes into them. I'm also a collector at heart and can appreciate when I come across something that you don't see every day. This car will always be special to me because of the history I have with it so it will never be one that I highly modify. I've gone through my ups and my downs with losing my cousin since he was such a close friend to me but his memory lives on just like all of ours will one day with our loved ones and the people who know us. At the end of the day life goes on and you got to keep moving forward.
As for ROTM. Like I said above just being nominated has made my whole year. I've never been to a car show with my car or let alone been nominated for Ride Of The Month on a Mustang Forum so this is pretty cool. [MENTION=17616]the5.ohh[/MENTION], I remember your car when you first started and give you major props for getting it to this point. I've enjoyed following your progress. [MENTION=14880]03DSGGT[/MENTION], it seems like you have spared no expense with all of the modifications you have done. Great work! Thanks again for those of you who felt it worthy of me to be among these guys. :headbang:
hotmustang95
Boynton Beach FL
I voted for Will. Really like what he's doing with that car. I like how everything looks OEM. It reminds me of mine back in the day.
All these cars are whack.
April fools. Great job and congrats fellas.
Mustanger
Southern Oregon
I voted for Will...because of the heart I see put into it! All are great cars & this is always hard to choose...It doesn't have to be the fastest or the most money invested...Good luck to all you are all winners!
J_Sty_
Tampa, Fl.
How do I get in on this ROTM action?
Orange 94
Orange 94
Alberta Canada
Bribes.
To vote, be on a desktop or desktop version mobile.
To get noninated... just be active and continue posting pictures. People will start nominating eventually.
J_Sty_
Tampa, Fl.
Bribes.
Haha im getting the hang of it so I should be more active [emoji106]
Having a nice car is also nice... since it's ride of the month. Don't count too much on post count to get nominated.
Status
peasant99
