Biggest Rear Tire 17x8 Factory Rim
BillG
Hickory NC
As the Topic say I'm looking for the biggest tire I can fit on the rear on a set of 17x8 cobra rims for my 95 convertible. I have 245/45/17 all around right now and would like a bigger tire without looking tacky. Not really ready to change rims to 18's as of yet since I'm just getting car back on the road. Thinking Nitto or BFGoodrich for tires at moment. The Plan is 24/45/17 for the fronts and 255/45/17 for rear, BUT if i can go bigger in rear then i would like to have that option.
evilcw311
Most Evil Member!
Louisville, KY
I’d have to drive out to my car and look but I’m pretty sure I’m running 275’s on my fronts. They’re 18x8’s though.
TrickVert
Woodland Park, CO
I believe you'll find that 245 is the widest recommended for an 8" wheel. 9" gets you to 275 which is what I'm running on all four corners on my '95. (Nitto 555's)
BillG
BillG
Hickory NC
Trick I know that I have read that the 17x8 rims that came on 94-98 cobras ra a 255/45/17 on all 4 corners. So im sure that 255 will more than likely be largest but figured from what ive read on here that someone would have ran larger on a 17x8 rim.
g36 monkey
Orlando, Fl
You can run a 275 on an 8 inch wheel, but it won't fit properly, and any "performance" gain will be generally nullified by improper fitment. I would either get a better 255, or get wider wheels if you're looking to go wider.
BillG
BillG
Hickory NC
Thinking Goodyear's, Nitto's, or Bfgoodrich on tires and still learning how big i can go without removing parts. Rims are on the list but its hard to find the ones that have the look i like LOL.
TrickVert
Woodland Park, CO
275/70-17's on a 9" wheel will fit all the way around without any modifications. Mine just barely rub the sway bar at full lock, but it's minor.
315/40-17's in the rear on a 10.5" wheel with the proper offset should fit fine as well. Even wider in the back, (up to 335's, I've read) can be stuffed back there, but require flipping the quad shocks and probably rolling the fenders.
There are lots of wheel choices for our cars. I'm sure you can find something that strikes a chord with you.
evilcw311
Most Evil Member!
Louisville, KY
Mine are 18/9 up front. Not sure why I thought they were 18/8
Tillerman77
Southern MN
When it was time for new tires on my 97 Cobra, I backdated the tires to 255/45/17 on stock wheels, using Continental DWS06 tires. Looks and drives great.
g36 monkey
Orlando, Fl
Just dump the quadshocks. We fit 345s on a 10.5" wheel (dumb, but it happened) and it fit on an IRS car.
That said 315 on a 10.5" wheel is the usual accepted max.
TrickVert
Woodland Park, CO
Do NOT just "dump the quad shocks." Even with aftermarket LCA's, and other suspension mods, wheel hop can ensue with the quad shocks removed. Feel free to pull them, but test extensively on different surfaces with the intended wheel/tire combo, and even then, keep them in the shelf in case you need to reinstall them.
evilcw311
Most Evil Member!
Louisville, KY
Odd part is most people who have dumped the quads and installed better lca’s with better bushings have noticed a much greater launch with no wheel hop.
TrickVert
Woodland Park, CO
And for every one of them, there's someone else who had to put them back on. There are numerous threads on Corral on the subject.
g36 monkey
Orlando, Fl
Better LCA are sufficient. I can speak with certainty that there may be a number of threads suggesting people had to reinstall their quad shocks, but there are countless examples of people removing them and having zero issue. But, there's enough debate about whether or not they are necessary all over the internet.
BillG
BillG
Hickory NC
Ok Folks million Dollar question here. Is a 17x9 or 18x9 with factory offset which im guessing is +30 to big for front end. What size and measurement who some recommend? Gonna buy rims and tires and just want to fill the wheel wheels and get as close to the fenders with no rube.
BillG
BillG
Hickory NC
My '95 GT with 275/40-17 Nitto 555 Extremes on 17x9 Steeda UltraLite wheels. I have a 1.5" drop, and have never hit the fender(s).
Those are pretty close to the rims I have now at 17x8 trying to find the 17x9 twin to keep the factory feel. I’m hoping to getting mine to looking that nice.
TrickVert
Woodland Park, CO
Thanks. I'd considered changing things up a number of years back, but there's just something about these UltraLites that I really like. The look is classic, and the unique-ness of them is a bonus. About the only wheel I think I'd trade for is the UltraLite II, but even that, I don't know. (They're rare as hen's teeth these days.)
28279150_635844810080052_6318952186368320534_n2-jpg.926730
TylerGT
