Bump steer kit
ReplicaR
Bumpsteer kit replaces your tie rod ends. It bolts up to the rack tie rod on one side, and a spindle on the other side. The reason why you want to get is because a on a lowered mustang control arm and tie rod no longer travel on the same curve. The main difference between the standard tie rod end and bumpsteer kit is that bumpsteer kit allows you to space the distance between the spindle, and the rod end. This will allow you to get the original geometry back, and will reduce the chances of wheel turning itself in and out while the suspension is being compressed.
95DarkGreenGTS
95DarkGreenGTS
Bossier City LA
well my car is not lowered, but i was thinking about changing the tie rod ends and also the ball joints. Would it be worth getting that bump steer kit insted? So let me get this right the bump steer kit replaces all tht tie rod end. Inner and out?
how do you know how much space to put on the bump steer kit? i like mike install mine and would like to know how to properly space them..
ReplicaR
MM sells a bumpsteer gauge that measures the bumpsteer.
From what I've heard you basically just want the control arm and tie rod to be parallel. I was talking to an MM rep a while ago and he said the gauge is pretty overkill.
white95
Apex Junky
Admin
Prairieville, LA
OnyxCobra said:
white95 said:
overkill is fun on Halo 3
lol yes because you're not paying extra for it.
right you are... I wont be buying the bumpsteer guage with my bumpsteer kit... i believe thats geared more towards performance alignment shops anyway
95gtdrop
sacramento
I have. A prokit mm caster camber plates and koni yellows about to get installed . Do I need a bumpsteer kit?
alleghenyamerican
