Camber bolts
NicksGTR
Installed caster camber plates (Steeda) on lowered 01 Bullitt. Over bumps I get a "clunk" both sides. I need at least 1.75 neg camber for current wheel set up. I'm thinking of going back to stock strut mounts and Eibach camber bolts:
Anyone with experience with these?
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
No direct experience, but folks have been using them for a long time. If you do install them, just make sure you get the bolts tight. Very tight. If not, they will move around.
You say you have clunking after the plate install, did you make sure to shim the strut shaft correctly? And is the strut nut tightened all the way down?
badass98svt
This.
Make sure you have all your spacers/shims done correctly. It could possible be the bearing in the plates. Only plates I recommend is MM.
Suprasuavy
