Cobra rear brakes?
skunkworx
I have installed the Cobra front brake kit already if I do the rear would have to change the calipers. (Since they are not in the kit)?
Venomous96Cobra
Central Florida
no its the same caliper! I did the kit and it basically relocates the stock caliper to fit the bigger rotor! which is exactly what the cobra setup is...
skunkworx
The reason I'm asking is I was looking at part #'s on NAPA's website and they have two different #'s for them. At least replacement calipers.
mikey94gt
You get a vented rotor with the cobra setup, along with brackets. you can get Cobra brakes, but the GT is basically the same caliper.
skunkworx
Ok thats cool so far. Just checked Hawk for part #'s and they show two different #'s also. (for the pads)
skunkworx
Also shows suggested parts that they are needed IDK? Does you wear on the rotor like normal?
skunkworx
OK I have it figured out! The caliper is the same but the caliper bracket needs to be widened were the rotor passes though the bracket.
DropTopPony
South Jersey
The pads are different because the are thinner to compensate for the thicker Cobra spec rotors.
skunkworx
Javi do you think that I'm rich? I already have the Cobra set up anyway just trying to get it all figured out before hand. I don't like surprises. With me working nearly 7 days a week and a family my car sets on jack stands enough as it is lol!!!!!!
Suprasuavy
