Cut bbk springs?
TLSF150
Currently my car is dropped with BBK 2501 springs which is suppose to be about 1.5 drop..
Im wanting to drop it about another half inch so.. can I cut the BBK springs like the stock ones? (I know its not ideal but it works)
Heres how the car sits now..
Sent from my Galaxy S3 using Tapatalk 2!
Musturd
I like the stance . I don't mind cutting coils to get the stance I want
are they a standard rate spring, or a progressive rate spring?
from what i understand (and I could be WAY OFF -- so someone feel free to put me in my place)
you can cut a standard rate spring without problems, but if you cut a progressive rate spring you're messing up the functionality of the spring.
I got BBK Gripps and they are a stardard rate spring.
also, I'm with musturd. I like your stance, I just think you need to space out your rear a small bit ;)
whiplash473
Northern IL
the BBK's you're running should be fine to cut.....i'd cut the wide end tho
Do you have your isos in? If so, just remove those and you'll get the drop you're looking for.
T
TLSF150
I think it does have the isos.. I didnt even think about that... thanks man!
To everyone else their specific rate and yeah im pretty happy with it I just wakt it a tad bit lower to close up some of the wheel well gap
96TANGERINEGT
I wanna cut mine too , but just affraid that I will cut to much off then not be able to dive the dam thing anywhere .. hahahah
Mine has 2 inch lowering springs , but I have 18's so kinda sits a little higher ..
Def. pull the iso's first and see how you like it.
Pick up a pair of 1" spacers for the rear and you'll be set.
chris91
Cincinnati, OH
Id say pull the iso's and if you dont like it then, try to find someone to trade springs.
T
TLSF150
I just hope the isos are in there.. that will save me a lot of trouble haha
white95
Apex Junky
Admin
Prairieville, LA
If theyre indeed a set of progressive rate springs, DON'T cut them. Buy what you want and sell the ones you have.
white95
Apex Junky
Admin
Prairieville, LA
Yes, standard = specific..
I'd cut 1/2-3/4 of a coil to start and see how that looks. Remember, you can always trim a little more but you can't ever put it back!!
bopate
Powell, Tennessee
If you take the isolators out, don't throw them away. I took mine out and now the springs squeak. I know a lot of people that took the isolators out and never had a problem but I have to put mine back in
Did you wrap them to prevent metal on metal contact?
bopate
Powell, Tennessee
Lol no I've never known anyone to do that. I'm just going to cut them some more and put the isolators back in.
If you wrap them with electrical tape they don't have any more metal to metal contact, thus removing all the squeaks you hear on the road.
I've had mine removed for a couple months and I have yet to hear a sound.
Suprasuavy
