Dyno Tune 95 5.0, Trickflow HCI estimated hp?
the5.ohh
Shaolin, NY
95 GT.
Trickflow Twisted Wedge 170cc heads
Comp Cams 1.6 RRs
Trickflow Hardened Pushrods
Trickflow Stage One Cam
Autolite Plugs (forgot which ones, but recommended by trickflow)
Livewire 10MM Plug Wires
Comp Cams Double Roller Timing Chain
Ford Racing Water Pump
Trickflow Streetburner Intake Manifold
Trickflow 3/8" intake manifold spacer
BBK 70mm throttlebody
C&L Ram Air Intake
C&L 76mm maf calibrated for 24# injectors
Ford Racing 24# Injectors
Walbro 255 LPH Fuel Pump
All ARP Hardware
MAC Longtube Headers
MAC Shorty Offroad H
Borla Stinger S-Type Mufflers
EGR Delete
Smog Pump Delete
MSD 6AL-2 Ignition Box with 2 Step
Aeromotive Adjustable Fuel Pressure Regulator
Aeromotive Fuel Pressure Gauge on the fuel rails
All new gaskets, new front and rear main seals.
I just installed a set of electric water temp and oil pressure gauges. I'm sure I probably missed a few things. What kinda power should I expect with a dyno tune? GT40 setups net like 270-280 whp, I'm really hoping for 300 whp. I have a CEL on, ran the code and its for the egr delete as I expected. Car has some drivability issues but that's to be expected with mods like this on a bastard 94-95 without a tune. Car runs well despite a few issues, pulls really well in every gear. So waddya think?
the5.ohh
the5.ohh
Shaolin, NY
[MENTION=10188]white95[/MENTION] could ya move this to the dyno section por favor jeffe? Gracias
1998cobrasvt
Whats the status on going to get tuned at wicked? All your questions will be answered then at the dyno session the5.ohh
lutter94
South Dakota
What you going to use to tune it? Make sure whatever it is,they disable the egr function. Cel goes away
Sent from my SM-G930V using Tapatalk
the5.ohh
the5.ohh
Shaolin, NY
Most likely they'll provide an SCT chip. Egr function will def be turned off.
I thought they advertised 300 hp with the trickflow top end kit which is what it looks like you have.
Srchop16
