Few rim/tire questions....
BruhBrahBrad
Ok Im sure this has been asked before, but I couldnt find much in a search.
Will a 275/40/18x9.5 fit on the front
And how does it look in the back, I'd like to be pretty wide, but also be able to rotate.
The rims in question are y2k cobras.
You'd want to go with a 275/35 for 18" wheels, you might have a little clearance issues with turning up front with a 275 but they should work good all around.
B
BruhBrahBrad
Yeah these are the rims in question btw...
98GTnSC
nice looking wheels! but yeh upfront u may have a little issue but idk. ive got 9" wheels all around and i think 9" upfront fits perfectly. but they look good and good luck
I've run 18x9s up front with 275/35s on 2 seperate sets of wheels...they rubbed on full turns, but not too bad...
I went with 265/35s on my FRs
Win
Kennesaw, Ga
If you want to rotate just run 265/40/18 That is actually the stock size for Y2K's
yeah that'll work but they're not gonna look really wide out back, but you probably won't notice a difference between those and 275s.
B
BruhBrahBrad
What size would look best on the back of my car? a 285? btw its a 9.5 rim not 9 it might not make much difference though...
Win
Kennesaw, Ga
Im going to throw a 295/35/18 on the back. Run a Goodyear Eagle F1 GS-D3. Then a 265 up front
Win
Kennesaw, Ga
It they aren't OEM or FRPP it could be a 9" look on the back of the spoke.
the ideal size for the rear of our cars and what fits properly on a 9.5" rim are a slightly different story, i personally like anything 295 and larger, which you could probably fit on the 9.5" rim. however if you want to be able to rotate your tires that's not going to work well for you.
B
BruhBrahBrad
Yeah its a 9.5 it says 18x9.5 on the inside of the spoke.
Win
Kennesaw, Ga
Then if you want to be able to rotate them and not have as harsh of a ride just go with a 265/40/18. If you want a Lower Profile tire then go 265/35 all the way around.
Suprasuavy
