Fill hole size
Pallgor
I’m going to change my trans fluid in my 5 speed to Synchromax and I’ll need a hose to use install the fluid. I want to know what size the hole is to get a hose will fit.
Ty
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
What trans do you have? It should be a 3/8npt pipe plug that’s in there. If you get one of the cheapo transfer pumps from harbor freight, it’s got two red hoses on it, one goes in the bottle one goes in the fill hole. Pump till it dribbles out.
P
Pallgor
My door jamb sticker code says 6. Idk what that code represents
P
Pallgor
Trans is filled. Used a old piece of rubber fuel line. It took 3 & 3/4 qts to fill. Shifts better but may need new synchros down the line but good for now
Thanks for all the suggestions
Srchop16
