front struts ???
pliego23
should i go with the lakewood front struts 70/30 or 90/10 or what other one will be good for 94 mustang
P
pliego23
or should i get kyb i got k member, a arm, and, coil over with eibach springs so what should i put on it
ryclef331
I run 90/10's on the street all the time. If you keep the front sway bar, it will be just fine. Just remember, its not going to handle like it did stock so carving corners is not going to be a strong point.
P
pliego23
thanks my car does not have the front sway bar the car did not have it when i got it . should i get one?
P
pliego23
its for everday use and i want it for streetracing too
94 DropTop
I just installed drag springs, 90/10's on my and took off my sway bar. Couldnt tell you how it drives though. I have a sway bar if you want to buy it.
Suprasuavy
