Ground question
Poppinabeer
I was wondering if all the grounds on my sn95 with a 351 Windsor that is normally aspirated can be attached to the intake on the rear drivers side post?
Thanks
P
Poppinabeer
I was asking about grounding wires going to the driver side intake . I have not found the grounding strap yet but I think it comes from the battery directly to the chassis
badass98svt
This is obviously a custom install? Who did the swap?
P
Poppinabeer
I'm don't know . I bought the car from a young man that was moving. So I'm trying to clean up mistakes ?
The intake is not the ideal location, you want it bolted to the block itself. While the intake is metal there are a couple of points of connection with gaskets between them that make it just not the best spot. I recommend using one of the bolts that holds the starter on myself. It goes straight to the block and the starter draws more current than anything else in the motor so having it go straight to the chassis(assuming your chassis is properly grounded to the battery) is the best way.
Superman3872
