Need a little help here...
My '98 has had a leaking trunk sice I bought it a couple of months ago. I got in the trunk while someone put the hosepipe to it and it was leaking in the middle of the trunk lid where the weatherstriping is. I bought new weatherstriping and that has not fixed the problem. I have look at other places for leaks like around where the gas fill tube is (its fine) and there seems to be no other places that leak.
The only thing I see that may cause the leaking in the same place after the weatherstriping is there is a rubber piece that runs along the bottom of the rear windsheild. In the spot where the trunk is leaking the rubber is loose in the same place on the windsheild....
I may try to glue the rubber back to the window and see if that helps... anyone else have any ideas?
Thanks
Thanks
