Highlighted posts from Monday, Jul. 04, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 03, 2022 * 9 posts * 85 views
ttocs said: Looking at the 94/95 oem electrical manual it really doesn't show much about it. I might have been imagining things but I thought I remembered at one time that the radios with ... Read more >>
July 04, 2022 * 3 posts * 15 views
SN95_Project said: Can someone point me (or show pics from their car) to a wiring diagram for the ABS sensors? My son and I are finally working on the suspension kit we bought from MM and when we ... Read more >>
July 04, 2022 * 3 posts * 10 views
TrickVert said: I installed LED tail light bulbs awhile back, and like others here, have been living without my cruise control since. The circuit below fixes the problem using one 5-pin 12VDC ... Read more >>
July 04, 2022 * 5 posts * 62 views
LEGALLYFAST said: Like he said, it takes a bit more time than you think. Start farthest away and go from there. Make sure you don't run low on fluid. Read more >>
July 04, 2022 * 5 posts * 74 views
LEGALLYFAST said: It depends on how aggressive you are and your budget, but Centerforce clutches used to be a good upgrade years ago. I personally like McCloud twin disc, because they have light ... Read more >>
July 03, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Drifty, floaty sensation at speed July 03, 2022 * 12 posts * 73 views 94-95 5.0 - Specific Issues after '00 CobraR brake swap July ... Read more >>
July 04, 2022 * 24 posts * 585 views
LEGALLYFAST said: Have you checked for any other vacuum leaks? I would recommend getting a smoke machine. You could be diagnosing and have a different issue. At least this will verify you have no ... Read more >>
July 04, 2022 * 24 posts * 915 views
LEGALLYFAST said: Are the O2 sensors OEM? I know that aftermarket sensors don't always work out. Read more >>
Continue reading...
Srchop16
