Highlighted posts from Monday, Jul. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 25, 2022 * 12 posts * 64 views
07GtS197 said: You can insert a nylon spacer around the throttle linkage at the pedal end. It will tighten the cable and move the pedal up. I've done it before myself. Most likely you'll find ... Read more >>
July 24, 2022 * 15 posts * 102 views
Michael Plummer said: The stock 94-95 Ford cooling fan settings according to CBAZA (94/95 Ford Mustang strategy) along with a stock thermostat 192F to 195F. Low Speed On Temp 216.00 Low Speed Off Temp ... Read more >>
July 24, 2022 * 8 posts * 51 views
Notthenow said: If it has newer synchos (it was rebuilt before) the carbon fiber material on the synchros can respond well to some friction modifier like used in rear axles for the carbon fiber ... Read more >>
July 24, 2022 * 8 posts * 39 views
sn95slobrah said: He voltage was low, 11/12.... Also the very hot battery was spewing water and battery acid at the sides. I removed or, will replace with a high quality, tested, used one tomorrow. Read more >>
July 25, 2022 * 4 posts * 22 views
07GtS197 said: You should still be able to get those from Dorman. They at least have an assorted set that might have one anyway. Read more >>
July 24, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Cooling fan July 23, 2022 * 12 posts * 34 views 94-95 5.0 - Specific URGENT! Need a PI intake, will this one do? July 23, 2022 * ... Read more >>
Continue reading...
Srchop16
