Highlighted posts from Monday, Sep. 19, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 18, 2022 * 23 posts * 114 views
ttocs said: It is on the very top of the gas tank. You would need to drop the tank and then you will see the line going to it. It just pushes in/out, again plan on replacing the tank neck ... Read more >>
September 19, 2022 * 11 posts * 94 views
cobrajeff96 said: BLUF: hardly any Mustang is going to brake like a Porsche unless there's big money behind it. The only way you'll increase brake torque is to increase leverage which means larger ... Read more >>
September 18, 2022 * 50 posts * 427 views
94StewFord said: So where is PIN 13 and 14 located exactly? The air bag diagnostic monitor measures the voltage at Pin 14 of the air bag diagnostic monitor connector. Voltage at Pin 14 should be ... Read more >>
September 18, 2022 * 2 posts * 30 views
Silver95bird said: I've been looking all morning and not having much luck. The passenger side rocker panel is crushed in on my 96gt, and I started pulling it with my stud welder yesterday. The process ... Read more >>
September 18, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Gas tank hard to refuel, can hear gas backup filler September 17, 2022 * 11 posts * 51 views General Tech Heads question September ... Read more >>
September 19, 2022 * 11 posts * 151 views
duh09 said: Got the car cleaned up Friday by the possibly homeless detailing neighbor to one of my stores... I don't ask too many questions in Memphis... but anyways, stopped and took some ... Read more >>
September 18, 2022 * 11 posts * 142 views
b1pig said: Nah. i would not worry about rust on the regulator. Read more >>
Continue reading...
