Highlighted posts from Thursday, Sep. 15, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 14, 2022 * 26 posts * 238 views
94StewFord said: Anyone familiar with what another member added on a separate thread on here: The plug for the module has a plastic piece that when the plug is removed from the module you install ... Read more >>
September 14, 2022 * 7 posts * 38 views
Lazerred98 said: so, on my 98 base model, the original factory size tires is 205-65-15 with a SL load rating. I have changed to 16 inch wheels, and now have 205-55-16 tires with XL load rating. ... Read more >>
September 14, 2022 * 10 posts * 70 views
TrickVert said: If you install 24-lb injectors, you will need a tune or a MAF meter calibrated for them, otherwise the computer will dump too much fuel thinking its still pulsing 19's. The computer ... Read more >>
September 14, 2022 * 2 posts * 22 views
Daryl said: Why is my "For Sale: tires and wheels (new)" thread no longer open to replies? There are interested parties and I'd like to make contact. Thank you... Read more >>
September 14, 2022 * 2 posts * 20 views
Nreed said: Does anyone know where I can purchase the fuel injector wiring harness for a 95 5.0 stock engine Read more >>
September 14, 2022 * 75 posts * 991 views
b1pig said: If you have not seen what the EPA had been doing, look at what happened to PFI Speed and JH Diesel. Not even thinking about Diesel Brothers.... They've gone after the retailers. ... Read more >>
September 15, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts This $#!+box, now P1740 code, trans solenoid? September 13, 2022 * 31 posts * 208 views Drivetrain Plug gap on a supercharged Engine? ... Read more >>
September 15, 2022 * 11 posts * 138 views
Daryl said: No, I have a full set (4) matching silver FR500's: Front: (2) 275/40x17 Nitto 555 G2 on 17x9 wheels; Rear: (2) 305/45x17 Nitto Drag Radials on 17x10.5 wheels. Then I also have ... Read more >>
September 14, 2022 * 9 posts * 120 views
b1pig said: If this falls through again, try taking that regulator assembly to one of your local fab/steel shops. Ask if they would be willing to weld up (build up the tooth height, not fill ... Read more >>
September 14, 2022 * 25 posts * 404 views
weendoggy said: I second the MMKM-2 for the 4.6 or Coyote. It is a very nice piece and you can spend more doing some other front suspension stuff. I was thinking the MT-82 in my swap, but came ... Read more >>
Continue reading...
Suprasuavy
