Highlighted posts from Saturday, Dec. 04, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
December 03, 2021 * 11 posts * 51 views
ttocs said: I thought that you were only able to store 3-4 codes before it was full and then needed to have the memory deleted and then you could store more but I only had to mess with it ... Read more >>
December 03, 2021 * 6 posts * 50 views
Jakespeeds said: And I can tell you from first hand that BBK does not carry the correct pump for a 98. No matter what they tell you. Ended up going to Walbro after BBK sent me 3 separate pumps. ... Read more >>
December 03, 2021 * 2 posts * 12 views
BigBillFL said: My passenger door lock switch operates the window and my window switch operates the door lock. I thought these switches were modular and couldn't be plugged into one another. Is ... Read more >>
December 03, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Throttle body changed... December 02, 2021 * 11 posts * 105 views 96-04 - 2V Specific Does anyone know the reason behind the different ... Read more >>
December 03, 2021 * 13 posts * 270 views
tvsn95 said: Hey Guys,, Contact Adam @ Pops racing . He does remote and will let you know what can be expected without all the drama. 585-802-6911 Fun fact. Adam reverse engineered the ford ... Read more >>
December 04, 2021 * 16 posts * 750 views
Katstang said: Also, sometimes the security system goes nuts for some reason and it will stop the fuel pump from working so all it would do would be crank without starting, sometimes unplugging ... Read more >>
Continue reading...
RevJon
