Highlighted posts from Saturday, May. 28, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 27, 2022 * 21 posts * 180 views
Snorky said: Let me empart some wisdom to you. Use a gear/mph calculator linked here. That will help you figure out your current gear ratio. Just google your transmissions ratios, and add your ... Read more >>
May 27, 2022 * 16 posts * 262 views
dwcopple said: Not flawless, but, far better. I'll probably do it again at some point. Read more >>
May 27, 2022 * 8 posts * 56 views
Snorky said: Interested in the spoiler, can you get a quote shipped to 07438 Read more >>
May 27, 2022 * 4 posts * 69 views
Snorky said: I also get them from Briantooleyracing.com. click the top right and search 2v. And the valve spring options come up. Have ran the .600" extremes in my 4.6 before. Picked up the ... Read more >>
May 27, 2022 * 3 posts * 70 views
Snorky said: +1 on the billet oil pump gears, MHS and CMS make great cams. The stock pistons can only take so much lift without valve reliefs being cut into them. So just keep that in mind ... Read more >>
May 27, 2022 * 1 post * 14 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 Cobra Gearing May 26, 2022 * 15 posts * 115 views Drivetrain A/C clogged: Where to find expansion valve @ 94 GT ? May 26, 2022 ... Read more >>
May 27, 2022 * 4 posts * 62 views
96blak54 said: I would suspect a faculty sendor such as mass air flow, throttle position, or cam position. Try unplugging one sensor at a time and take it for a drive. Read more >>
May 27, 2022 * 16 posts * 270 views
i86hotdogs said: You're absolutely right on the ceramic point. I was generally speaking of the difference between the materials. A pair of cheap autozone cermaics won't hold a candle to a more ... Read more >>
May 27, 2022 * 11 posts * 236 views
Snorky said: A little late for the party, but you dont really need cams and springs with 4v motors for something like 16-18lbs. Springs are necesary if you get high lift cams, start pushing ... Read more >>
Continue reading...
Carolinastang78
