Highlighted posts from Sunday, Jul. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
July 16, 2021 * 11 posts * 61 views
J_lope82 said: I recently bought a 96 mustang GT with 4.6L 2V. It has a PI swap including heads, cams, and intake. It came with a lokar aftermarket dipstick but it's all messed up and leaks oil. ... Read more >>
July 14, 2021 * 17 posts * 122 views
Notthenow said: I had heard they would custom grind on request for a new order, didnt know they would do that on already finished product. Wasn't Bullet also doing some special grinds designed ... Read more >>
July 14, 2021 * 28 posts * 323 views
Frank.JD.Perez said: ive been running the steeda tri ax with the factory knob for about 10 years so... take from that what you will Read more >>
July 16, 2021 * 3 posts * 43 views
joemomma said: Been fighting some idle issues with the car, but only when the AC is on. More specifically, if the AC compressor has cycled on, and I'm low engine speed, it'll tend to die - especially ... Read more >>
July 14, 2021 * 26 posts * 265 views
07GtS197 said: I adjusted the firewall adjuster to take out the slack. It's weird because the clutch is inconsistent. I went out to move it and it acted like normal though I'm sure it's still ... Read more >>
July 17, 2021 * 1 post * 10 views
07GtS197 said: I have a weird one for you guys. My 00 Gt has intermittent power steering. It'll work fine when it first starts then I turn the wheel, power steering fluid level drops to the low ... Read more >>
July 16, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Hydraulic Clutch issues July 15, 2021 * 26 posts * 242 views Drivetrain Highlighted posts from Thursday, Jul. 15, 2021 July 15, ... Read more >>
July 17, 2021 * 7 posts * 275 views
Knightstallion said: Man i hope you get your baby straight faster than me, I've got the 95 gt and she's been giving me hell for almost 2 years, when i think I got it fixed it runs a couple weeks and ... Read more >>
Continue reading...
Suprasuavy
