SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 16, 2022 * 18 posts * 212 views
KasperBPMC said: The relay is missing and so is the bridge in the fuse block. Yes, switch is in the center console, if you pull your fuse box out of the engine and flip it, you can add the parts ... Read more >>
June 15, 2022 * 17 posts * 248 views
Stangswagalicious said: So... although it did help, it did start pinging again but not as bad. I had yet another epiphany as well tho. The day i got the car i noticed a certain uh.. hissing noise that ... Read more >>
June 15, 2022 * 7 posts * 66 views
joemomma said: Ran fine on the way home and this morning, so that's a relief. Read more >>
June 16, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Shimmy and shake under load? June 14, 2022 * 6 posts * 36 views General Tech Spark knocking galore... June 15, 2022 * 14 posts * ... Read more >>
June 15, 2022 * 2 posts * 61 views
SilverStang said: Update: got them fitted... required that I use the caliper adapter bracket opposite to the instructions from FTR. This mounted the caliper higher up and gave me the slack I needed. ... Read more >>
June 15, 2022 * 24 posts * 357 views
ttocs said: As mentioned above the temp can effect how well the harness is or is not touching and making enough contact to work or not. Read more >>
June 15, 2022 * 101 posts * 1,367 views
white95 said: I'm not sure if mine was changed or removed, so, I need to check as well. Any additional brace, rod or suspension component installed with solid/spherical bushings, clamped to ... Read more >>
Continue reading...
